tC-3 Spark Plug Wiring - NCRS Discussion Boards
  • James C.
    • November 1, 2001
    • 137
    I have a 1971 454 Air Coupe. Do the brided wire spark plug wire ends that fasten to the valve covers on Cylinders #2 and #4 fasten on the # 2 Valve cover bolt together, or does # 2 coil wire end fasten individually to # 2 Valve cover bolt and # 4 braided wire end fit to the # 4 valve cover bolt.Also do these two wires run around the air conditioner bracket or through the hole in the bracket and fasten on the # 2 cover bolt like a non-air car.. AIM does not show how to do this...Thanks! Jim
  • D S.
    • March 1, 2005
    • 1551
    Re: tC-3 Spark Plug Wiring
    According to the JG the spark plug ground wires for 1970-1971 LS-5s and LS-6s are attached in pairs on the 1st and 3rd valve cover bolts on the passenger side and on the 2nd and 4th bolts on the driver's side. This will probably require longer bolts for those. The JG doesn't address the routing of the wires so I assume that would be up to the owner's discretion. Possibly looking at photos of restored Corvette LS5/LS6 engines might help you decide.
