Need your opinion on this item I picked up at Carlisle. This is the horizontal bracket that bolts to the RH exhaust manifold, to which you attach the front and rear supports/brackets for the compressor. Note the eyelet (complete with surface rust) which was machined AFTER painting, similar to brake calipers; same on the forward eyelet. I believe this part is NOS.
Notice the casting #; 3841696, which is the same # as is in the '65 AIM as well as the '65 P&A30 catalogs. However, the '67 P&A30 [Gr. 9.171] shows # 3878222 for '66 and '67. I believe the difference is that there is a circular "cut-out" in the area where the pencil points to in the photo. And I think that this change in design is to allow an A.I.R. (K19 option) injection tube to attach to the exhaust manifold.
All repro catalogs show this part with the indentation. BTW, my early '65 C60 car has the bracket as shown in photo.
So I'd appreciate comments on whether the proper (pre-A.I.R.) support is as shown in the pic., and that the latter indented style is for '66-up. I realize that the TM&JG's don't get into this detail (or they'd be as thick as a phone directory).
