Does anyone know if there is a kit with these bolts and washers? I assume not because I have been looking all over for some with no luck. If a kit is not available then is it possible, based on the part numbers, figure out what the washers and bolts should look like in regards to the type of head as well as how long they should be?
Just curious but why would the one bolt use a lock and flat washer while the other three use just a star type lock washer.
Thanks again.
Thanks again.
