My '70 heater hose has been chafing on the AC compressor (incorrectly routed hose) and needs replacement soon. (350/300 Auto, AC car)
The judging manual mentions molded hose ends which *may* have the GM logo on them. Are these hoses still available through GM or am I relegated to the repro catalog houses... of they even sell a "correct" hose? It's sometimes hard to tell from descriptions/photos if you don't know exactly what you're looking for, and the catalog interpretation of correct isn't necessarily "correct" in the NCRS sense.
The dimensions listed in the JM refers (for example, there are several different ones needed) to a 1-1/4 inch tower (Wittek Mfg. Co.) clamps on the 3/4 inch hose. Is this the tower height across the max clamp measurement or what? Also, is there a good source for tower clamps with the appropriate date, galvanization / zinc plating? Is there a reason to NOT use the tower clamps (other than they're a PITA to remove later)? Is the tower part supposed to be pointing straight up when clamped?
Also, this hose attaches to a vacuum thing (which controls the flow to the heater core, downstream of it). Mine is just hanging out in the breeze. Is this correct or should it be bracketed to something? Any other details I should be concerned with from a judging point of view while I'm monkeying around in this part of the engine compartment?
Thanks, Juliet
Thanks, Juliet
