I checked the archives for a problem I am having with the headlight switch and was unable to locate an answer. The problem I am having is that the instrument/cluster lights only work when the switch is turned to the brightest position. When I try to turn them down to dimmer, they go out entirely. Also when turning the switch to turn the under dash lights on with the doors closed, the interior lights do not come on. I presume that the rheostat in the switch is the culprit, so my question is, is this repairable or just buy a new switch? If a new switch is in order should I look for a NOS 1995149 or buy a newer Delco model?
TIA
Rick
TIA
Rick
