71 shift pattern color - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    Was the shift pattern on the console all brite metal on a four speed? I'm restoring a 71 LT-1 with no TI&JM as it is not being sold and I have many questions. I would take an old copy on loan if anyone has a extra they are not using.
    Lyle
    Lyle
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 71 shift pattern color
    Lyle the shifter pattern is the same as your 73's color wise black back ground brite metal pattern. you can email me at poslansky@fuse.net. Phone 513-965-8009 Queen City crew
      • 43193
      Lyle-----
      The shift pattern plate on the console was not an integral part of the console plate; it was a seperate piece with an adhesive backing for attachment. The plate for all 1968-76 Corvettes with 4 speed was the same and was once available as GM #3918589. It's no longer available from GM. However, I believe that a perfect reproduction is available. The plate is mostly black-painted with the exception of the shift pattern which is "shiny" chrome.
