C2 66 front stabilizer bar link kit - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    I am installing the Paragon front stabilizer bar link kit. I bought the one with the poly bushings.
    I noticed the Paragon washers were substantially thinner than those currently on the car. Existing washers are approx 1/8" thick. I don't know if they are original but they have the hex recess. Car is not judged but I am curious what is correct. I plan on using the thick washers.
    Should I lube the poly bushing to prevent squeaks? With what?
    UPC 3 A5 says 9-12 ft lbs. on the bolt assy. Sounds light.
    Any suggestions appreciated.
    Randy
    Re: C2 66 front stabilizer bar link kit
    Randy -
    No lube needed on poly link bolt bushings/grommets; use the original thick washers.
    • Randy S.
      • January 1, 2003
      • 586
      Thanks John *NM*
