C2 - Hood Hinges - NCRS Discussion Boards
C2 - Hood Hinges
  • Dino L.
    • February 1, 1996
    • 694
    C2 - Hood Hinges
    I recently have been looking for a set of NOS hood hinges, my originals are worn out. I am trying to decipher the little differences in the various versions that I have found, I know about the spring washers and the W symbol with a line, but I am unclear on the waffle pattern on the head of the rivet. My 64's original are flat with no waffle pattern, I have seen a 67 set with waffle knurl pattern, does anyone know whaht characteristics go with which years?
    Dino Lanno
  • Frank C.
    • January 1, 1986
    • 277
    Re: C2 - Hood Hinges
    Hi Dino....if it'll help, I'll look at my presumably original '64 hinges and some 1974 circa NOS hinges I have....Regards Frank
    • Alan Drake
      Dino, Just looked at my hindges on a Mar 64 that have not been replace after spring of 66. (At present unable to trace back to 64)
      Pass side has waffle with the W
      Dr side is flat without the W
      Oh - what is the story on the W??
      Neither have been painted or show any indication of paint, JG will not like that - however I'm leaving alone and will take the point hit since more information may come about.
      Hope this helps - it probally just makes it worst.
      • Wayne W.
        • April 30, 1982
        • 3605
        Not painted on AOS bodies.
        • Michael H.
          • January 29, 2008
          • 7477
          Wayne,
          Are you saying hood hinges on AO Smith bodies weren't painted with blackout, or any other coating prior to blackout??
          • Wayne W.
            • April 30, 1982
            • 3605
            OOPs sorry I meant latches.
            • Jim W.
              • April 1, 2006
              • 228
              Checked my E64 (Nov63) last night. Head of pivot pin has 4 slashes as stated in the 63/64 JG. "W" on outboard side of drivers side and inboard side of pass. "E" headmark on all bolts. Underneath blackout is orig.exterior white paint on bolthead and hinge. Hope this helps.
