I have a 69 427 3955270 block. I am having difficulty installing the fuel pump. The engine is at TDC on the #1 piston. The fuel pump I am using is 6440659, type 40482. I cannot get the pump installed because the pushrod, while moved as far as possible toward the cam, does not have enough clearance. I have tried a small block fuel pump (type 40956) and this pump installs fine. Are there different size fuel pump pushrods for small and big blocks? Can I use a SB fuel pump? Any ideas on why the BB fuel pump will not fit? I have also tried rotating the engine several degrees without success. Thanks
69 BB Fuel Pump & Pushrod
