66 intake manifold #s - NCRS Discussion Boards
  • Harry Holzke
    Does anyone know if the intake manifold has dated numbers? Mind has 3885069. I thought this was the part number. Thanks
  • Tim E.
    • April 1, 1993
    • 360
    Re: 66 intake manifold #s
    According to my judging guide, 3885069 is the casting number for an aluminum intake manifold for a 425HP 427. "The casting date on aluminum intakes is located on the underside and is not visible for judging. The format is MDDY, where M is the month represented by the letters A thru L, DD is the day, and Y is the year." Tim
    • Kent D.
      • February 1, 1992
      • 100
      The date numbers are on the bottom of the manifold.
      • Harry Holzke
        THANK YOU!!
        Yes, it is a 427/425. I think it was stolen at one point and some paperwork I found had a new manifold listed on it (along with the wing window-hint, hint) thanks for your responces
