LS5 power brake vacuum routing - NCRS Discussion Boards
  • tom444634
    Early 71 LS5 4 speed with power brakes. I'm curious about the routing for the vacuum lines for both the power brake booster and the vacuum reserve tank. Currently the power brakes and vacuum reserve tank are both fed from a port on the intake manifold. The outlets of the port are 180 degrees apart. One of the ports is a threaded fitting for the booster and the other is a plug on for the tank.
    My question is, I see in the AIM for a 1971 that the power brakes are supposed to go to the base of the carb and just the tank comes off of the manifold. The car as I received it is fairly unmolested leading me to think that what is on the car is correct and the AIM is for later 1971's. Is it possible that what I have is left over from 1970 since my car was built in early Sept of 70? I don't have a 1970 AIM to check it against.
    Tom
    PS if anyone has pictures of this setup I would like to see them.
    • 15573
    Re: LS5 power brake vacuum routing
    Unless you are looking in the LS5 section of the AIM (with the options at the back of the book), the image you are seeing is likely that for the base motor small block. In general the images shown in the AIM are for the basic configuration. Any options illustrated will be called out in the title block of the page.
    • tom444634
      Terry,
      I believe that I was looking at the LS5 section of the AIM, but I'll double check tonight.
      Tom
