Once the differential and T arms are mounted on to the frame, what is the correct sequence to connect the shocks, spring, half shafts and struts. Any assembly hints would be appreciated. Thanks
mid year rear suspension assembly
Re: mid year rear suspension assembly
I dont remember the exact sequence that I used but I believe it was struts, half shafts, spring, and the shocks are easy and last. A floor jack is real handy. Use anti-seize on all bolts with new lockwashers and french locks. After I had finished rebuilding everything under the car, I drove it to a shop and had them put it on a lift and check all of the torques and then install the cotter keys, just to have another set of eyes chek it out. I did this even though I had been a mechanic for 10 years.- Top
