'64- 4 speed shifter getting stuck in reverse - NCRS Discussion Boards
  • Albert P.
    • April 1, 2006
    • 205
    Happens from time to time, trans gets stuck in reverse. Have to disconnect reverse shift linkage on trans, get trans into neutral, put ****er in neutral, then reconnect the reverse linkage. Do you think it is the shifter interlock causing this problem? Shifter is not too tight, pretty sloppy. Thanks.
  • William C.
    • May 31, 1975
    • 6037
    Re: '64- 4 speed shifter getting stuck in reverse
    Rebuild, tighten up the slop, and pay attention to centering the neutral gate per the shop manual instructions and you will be ok.
    Bill Clupper #618
    • Albert P.
      • April 1, 2006
      • 205
      Thanks for the advice Bill; from what I can see, from parts suppliers, a major rebuild kit is available and contains knob, spring, t-handle w/rod, shaft and interlocks.
      • William C.
        • May 31, 1975
        • 6037
        make sure you have a press available to compress the main shifter housing back to a point where all the parts fit without slop, also check the integrety of the weld where the housing wraps around itself to form the "box" the arms move in.
        Bill Clupper #618
        • Albert P.
          • April 1, 2006
          • 205
          Thanks for the advice *NM* *NM*
