1957 Corvette raidator in a 1954 - NCRS Discussion Boards
  • John M.
    • January 1, 2000
    • 175
    I have a 1954 Corvette project, will a 1956 to 1961 raidator fit in the core support and if so will the fan shroud fit also Thanks in advance..........John
    Re: 1957 Corvette raidator in a 1954
    John-----
    The 54 and 57 supports were the same, so the 57 radiator should fit into the 54 support. I do not know if the 54 fan shroud will work with the 57 radiator, but I expect it will.
    The other problem may be the inlet/outlet configuration. I don't know if the inlet/outlet configuration for the 6 cylinder application is the same as for the 8 cylinder application. So, there might not be any molded radiator hoses that will fit.
    • Michael L.
      • July 31, 2005
      • 562
      John, my '55 has a '56 radiator in it everything bolts in fine. Our radiator supports are the same.
      Mike
