C2 Main Brake Line Replacement - NCRS Discussion Boards
  • Brian K.
    • September 19, 2007
    • 174
    Can this be done with the body on the frame?
    Thank you
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Donald T.
    • September 30, 2002
    • 1319
    Re: C2 Main Brake Line Replacement
    Brian,
    What year C2 are you working on? The 63-65 brake line runs along the top of the frame rail, so you will need to have the body up off the frame to replace. The brake line was relocated along the side of the frame rail in 66, so you should be able to replace it on a 66-67.
    Good luck!
    • Brian K.
      • 174
      It's a 66 so that's good news and thank you!!
      66 Coupe
      66 Convertible
      2022 2LT Coupe
      67 Chevelle SS396
      • Jon #40768
        It is fairly easy. There is one snag. The front mounting clip is to close to the body at the last bolt on the frame near the firewall. I cut the clip, bent it out, replaced the line, and bent the clip closed. The cut is not noticable if you cut the clip at the top along the frame.
        Ain't it great to have a midyear that you can work on yourself?
        Jon
        • Joe R.
          • March 1, 2002
          • 1356
          Hi Brian:
          I managed to replace the line in my 67 while the body was on the frame, but it was VERY close getting the clamp bolts backed out of the frame side rail. As I recall, it was possible to get a wrench on the bolts and turn them about 1/4 turn at a time, but when the bolts backed out the heads hit the floor pan of the body at just about the same time as the threads disengaged.
          I was lucky and managed to get mine out, but my guess is that on another car with different assembly tolerances it might not be possible.
          • Brian K.
            • 174
            Thanks guys. I did recently change the body mounts and recall that I had to jack up the body at one point to get clearance to work & it wasn't too bad of a job. Since they are new mounts I know I won't have to worry about rusty bolts.
            I was concerned with the clearance around the rear frame kick up. That wasn't a problem for both of you?
            Thank you again,
            Brian
            66 Coupe
            66 Convertible
            2022 2LT Coupe
            67 Chevelle SS396
            • Joe R.
              • March 1, 2002
              • 1356
              I don't recall having a problem at the rear kick-up. All my trouble was along the side rail and at the front clip that Jon mentioned.
              • Jon #40768
                The rear was a piece of cake. wear glasses to keep the crud out of your eyes and be patient.
