Pull the tank today got some tank sticker
  • george culolias
    I think if I try and remove the sticker it will fall apart. What do you guys suggest? And what do the numbers on the top left of the sticker mean?
  • Tom R.
    • July 1, 1993
    • 3963
    Re: Pull the tank today got some tank sticker
    George:
    Nice! Take a full photo image and put the tank back in place.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • george culolias
      Does anyone know what the model and ident is?
      The numbers at the top left..What do they stand for?
        • 42936
        Re: Does anyone know what the model and ident is?
        George-----
        The model number, 19437, is the model designation used for Corvette coupes from 1965 to 1971.
        I don't know what the "Ident. Number" is. I expect that it's some sort of internal number used for order processing.
        • Harry Sadlock
          As I recall the Identification number is the same number that appears at the upper right corner of the Window sticker just under the Chevy Bow tie.I just assume it's a way to correlate/track information between documents.
          If you have a repro sticker made for your car, use that number.
          Harry
          • Tom D.
            • October 1, 1981
            • 2066
            George:
            At one time, your zone and dealer codes were on the upper right of this sheet. If you happen to know the dealer location and if they happen to have order copys from... Well... That's a real long shot, I guess.
            Tom D.
            4889
            http://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
            • Stephen L.
              • June 1, 1984
              • 3109
              As Joe said, the IDENT NUMBER was assigned when the order was typed. It was sequential and tied all the other documents together that were generated for a particuliar order. The number appears on this document as well as the window sticker, SHIPPER COPY, and the DEALER ORDER PAGE 7 which also carries the tank sticker info as well as the date codes of the engine, trans, diff, carb type, key codes, and VIN#
              • george culolias
                Thanks for the help everyone! Today was a good day *NM*
                • William L.
                  • December 1, 1988
                  • 944
                  Re: Thanks for the help everyone! Today was a good
                  How strange is the Exp. Date of Prod..9/00/00 ??? or am I just looking at wrong.
                  Bill
                  Bill Lacy
                  1998 Indy Pacecar
                  • george culolias
                    I noticed that too...wierd huh?
                    I just figured they were all like that.
                    • Philip C.
                      • December 1, 1984
                      • 1118
                      Re: I noticed that too...wierd huh? They were
                      Hi George They were dated like that some had nothing in the box. nice to see there still coming out to see the light of day again, too bad more of the sheet was not there. Phil 8063
