c1 convt. top rear bow pivot bolt hdwr. - NCRS Discussion Boards
  • don izzo
    I lost the acorn nut and one bushing when the bolt dropped out of the frame. suppose it's under the seat or behind the door jamb. I used a magnetic arm to locate the bolt , I'll find the others next time I have to remove the seat. Afraid I'll damage the paint if I do it now. Murphy looms large in my garage workshop!
    I am looking in Paragon and Corvette central. Both sell a pivot bolt set. Paragons has 2 bolts, 2 acorn nuts 4 bushings and 2 nylon and 2 s/s washers. C.central doesn't have the washers. Who's set is correct.
    Thanks for the help
    Don
  • Edward Boyd
    Re: c1 convt. top rear bow pivot bolt hdwr.
    Remove the seat - it only takes about two minutes.
