I'm consulting with a friend on a 327 engine rebuild. It has a 461 head on one side and a 462 on the other, both with the 1.94/1.5" valve set.
I found a spec for the 462s with the "small" valves of 62cc. The 461 should have slightly less volume because of the small spark plug side quench zone that is beveled on the 462 casting, but I can't find a nominal OE machined (not NHRA minimum) chamber volume for the 461 with the 1.94/1.5" valve set, but I figure it must be a couple of cc less.
Does anybody have a spec from a reliable source on the nominal OE machined chamber volume for 461s with the 1.94/1.5" valve set?
