C2 Coupe Vent window Removal - NCRS Discussion Boards
  • John L.
    • 409
    The weatherstripping (front and back) on the vent windows is cracking. I need to replace it. Are there are tricks for easily removing the vent window assembly and both weatherstripping pieces. The car is a coupe. I am concerned about scratching the paint or more when removing the vent window assy.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C2 Coupe Vent window Removal
    maring paint on removal of vent widow on coupe a definite possibility. the shop manual details the removal.remove door panel then main window glass assembly then the wisker channel that contact the upper and rear aspect of the main window glass then loosen the vent window fastners and tilt the vent backwards and inboard and upward, in that order. mask off the paint with dust tape or some such protectant. good luck, mike
