Thank you for your help. I checked the breaker and had 12 volts, just like I had at the switch. I assumed that I had a problem in the harness itself. I tested the wires to ground at the individual motors and had 4.6 volts. I will check the continuity of the motors as one does not even make noise. I also think I will hot wire the motors with a jumper wire from the battery to test the motor that does not move.
Thank you
Jon
Thank you
Jon
