Rear wire harness just replaced during frame off of C-1 1962. The brake lights work intermittently, when the turn signals aren't used. Sometimes one works, sometimes the other, sometimes neither. Using the turn signal will change which brake light works or does not work. If the left left signal is on the right brake light works but not the left, and vice versa.
When the lights do not work they are not getting power. I ran a ground wire from the block and checked power, nothing. Any help would be greatly appreciated.
Hank
Hank
