C-1 Brake and Clutch pedals - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Can anyone tell me the difference between a 58 clutch pedal and 59-62. I need a set for my 59 and found a person that has several but does not know the difference. Thanks in advance.
  • Mike E.
    • February 28, 1975
    • 5134
    Re: C-1 Brake and Clutch pedals
    There is no difference. 56-57 is different, 58-62 the same.
    • Anthony F.
      • December 1, 1985
      • 191
      Jerry,
      The 59's and later came with a clutch pedal that had a attached bracket for the clutch rod. This bracket could be put into 2 positions for standard clutch release or a quick release. I am not sure how the 58 clutch pedal was made.
      As far as the brake pedal I would presume that it is the same on either the 58's or later C-1s.
      Maybe someone with a 58 could add some information here.
      I hope this helps you some.
