Can anyone tell me the difference between a 58 clutch pedal and 59-62. I need a set for my 59 and found a person that has several but does not know the difference. Thanks in advance.
C-1 Brake and Clutch pedals
Re: C-1 Brake and Clutch pedals
Jerry,
The 59's and later came with a clutch pedal that had a attached bracket for the clutch rod. This bracket could be put into 2 positions for standard clutch release or a quick release. I am not sure how the 58 clutch pedal was made.
As far as the brake pedal I would presume that it is the same on either the 58's or later C-1s.
Maybe someone with a 58 could add some information here.
I hope this helps you some.- Top
