I had to take out the bracket support that holds on my gas door assembly on my 62 because the threads were gone on the stud.
This part was held on with two steel 1/8" rivits with the "smashed" part facing out. I searched the archives but the only reference on how to replace rivits was to put the part on a piece of steel and use a hammer to flatten out the rivit. This does not work when the part is on the car and there is fiberglass involved.
What do you guys use to replace the visible rivits and where do I get them? It is also a bit deep into the filler opening so access is a bit restricted.
I also want to replace the wire looms in the trunk which are also held on by rivits.
Thanks. Chris
Thanks. Chris
