57 heater fan switch - NCRS Discussion Boards
  • Paul Bowers
    is the 57 fan switch that is in the dash to the right of the steering column
    unique to early corvettes or is it poss. that it could be found on another pass. type chevy, I need to get one, or does anyone know where that switch could be repaired the switch I'm referring to also has the knob that pulls in and out thanks in advance
    paul
    Re: 57 heater fan switch
    Paul -
    Try Mary Jo Rohner (www.vettegal.com) - her husband used to rebuild them.
    • William C.
      • May 31, 1975
      • 6037
      It appears the same switch was used 53-57, at leasp per the '60 parts book, P/N 3141442, Group *.852. What is wrong with yours?
      Bill Clupper #618
      • Paul Bowers
        Bill, I was hoping the switch may have been used in some older other type vicicle truck ect. cause as you know mention word (corvette) and price goes way up ,my switch works fine as far as low, high and off but the knob that pulls in/ out for defrost has come loose on the back side of switch so I can't make the cable work thanks
        paul
          Paul------
          The switch you seek is a Corvette-only item; it was not used on any other applications that I can find. It definitely was not used on any other Chevrolet applications.
          • William C.
            • May 31, 1975
            • 6037
            It may be possible to replace just the wire in the cable sheath perform a new attachment to your cable and get you back in business. I believe such services are advertised in the "services" section of "Hemmings" or possiby in the "Driveline"
            Bill Clupper #618
            • Paul Bowers
              thanks joe
              paul
              • Paul Bowers
                thanks Bill this may be a winter project,
                also do know of any persons who do a good job of repairing my 57 steering wheel this also may be a winter project if not I may post a (?)
                paul
                  Paul -
                  Richard Dunham does outstanding work restoring C1 steering wheels, including color match and graining. E-Mail dunco1959@sbcglobal.net, (517) 339-8225.
