C3 (70) Judging Brain Teaser...Or Not... - NCRS Discussion Boards
  • Chuck S.
    • April 1, 1992
    • 4668
    It is widely known that Carter manufactured Rochester Quadrajets for some early C3s, and the dating format has been in the 70-72 TIM&JG since at least the second edition. I seem to remember a Restorer article was even written about the periods when Carter Quadrajets were supplied.
    How about Carter fuel pumps? Has anyone seen an original Carter supplied fuel pump on, say a 69 or 70 Corvette base engine or L46? It would be in exactly the same configuration as the AC supplied pump; i.e. crimped cannular pumping chamber, with two angled tube connections for fuel inlet and return hose connectors, plus a threaded outlet for the hard line to the carb on the bottom of the can.
    If you encountered such a pump on the judging field, and it was devoid of the sancrosanct "AC" logo, would it be a full deduct? Easy call if you go by the book. What if it had a Julian format date (0-195) cast into the vertical portion of the head that was 14 days prior to the car's build date?...The day-of-the-year portion is clearly on a removable pad that can be changed daily. Coincidence?...Or, rare previously unobserved pump type?
    What to do???...Profit from possible hither-to unknown facts about old Corvettes, or diligently protect the hobby from a fraudulent imposter? Smite the perpertrator of this outrage?...Or, throw the baby out with the bath water?
    There are some other numbers (more than one) stamped on the bottom of the both sides of the flange...not the pre-requisite "40769" number you want to see, but "other" numbers. Let's hear some opinions on the above, then I'll tell you what the other numbers are.
  • Chuck S.
    • April 1, 1992
    • 4668
    Well, Aw Rite Thin...
    Yawl don' wanna tawk 'bout jedging...I'm down wid' thet! (Thanks for the cool tutorial, Travis. (Groans in the background) )
    Photo credit to gtrman100, Simi Valley, CA
    • Travis Williamson
      Re: Well, Aw Rite Thin...
      Nice Teeth Chuck!
      • Chuck R.
        • April 30, 1999
        • 1434
        Re: Why Gorsh Chuck
        I gut mysef eight....uh wait a minut.....1,2,3,4,.....yup ....8 Briggs & Stratton carbs off them metals dumpster queens an I plan on boltin em all up so I kin hav me thu first an only Corvit wit an 8 barrel setup.
        I'll bet the jedges would be scratchin their heads on thet 1 huh?
        • Chuck S.
          • April 1, 1992
          • 4668
          "I'm Sorry, The Number You Called Has Been..."
          "...Disconnected. Please hang up and try again."
          Ah got no opinuhn ohn thet!
