50% readout on 1967 Temp&Fuel Gauges - NCRS Discussion Boards
  • Mark Evans
    My Temperature and Fuel gauges were working properly up until about a month ago when they started reading approximately 30 to 50% of the real values. They respond to the key been switched on and off. However when I have a full tank of gas it always reads the same.Ditto for the Temperature ,it stays put even though the engine is hot or cold. Any suggestions ,before I dive behind the dash?
  • William C.
    • May 31, 1975
    • 6037
    Re: 50% readout on 1967 Temp&Fuel Gauges
    Check the engine and IP grounds.
    Bill Clupper #618
    • Gerard F.
      • June 30, 2004
      • 3803
      Mark,
      Check all you connections at the senders for good contact first. Flakey ground connections or contact at the senders, or the instrument panel is the usual. If both guages are doing it, the instrument panel ground is suspect.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
