Thanks to all feed back so far,hears my story.I bought a 1971 LT1 convert Vin#194671s101356,Build date B01=sept 1,Engine castdate H180,stamped VO819CGZ,with vin# stamped 71s101356 correct.Trans is P1M12B with same vin #.Rear is AB W229 1 =370-warren-aug 17 1970-1st shift,Vin # also stamped on left rear of chasis.All looks good so far right.
Here's problem,No T.I. ignition nor holes for mounting it,Auto trans hole cutout in floor board,factory cut with small hole for shift cable.Can any one explain this.Car has had body off and several paint jobs.
