TIP: PB booster frontside rod adjustment
  • Geoff C.
    • June 1, 1979
    • 1613
    Power Brake Frontside Push Rod Adjustment
    Recently another member suggesting adjusting the push rod on the frontside of a 68 PB Booster. This is a result of mis-information repeated after the same 1963 Corvette shop manual photograph was used in later manuals. I’ll explain. Some of the 1963 Corvettes used a Moraine PB Booster that indeed had a small adjustable hex headed screw in the tip of the frontside rod that pushes against the master cylinder piston. All 1964-1967 and 1968-1982 Corvettes DO NOT have that adjustment feature on the frontside push rod.
    However, if one looks at later factory manuals, that 1963 picture is usually used. When the Chilton, Clymer derivative books regurgitated these factory books, the same error was propagated again and again. It infers all the subsequent model had a frontside adjustment, but they simply did not.
    Yesterday a member asked me for an exploded view of the 68 Corvette master cylinder showing the complete guts. I looked in my 68 Corvette part manual, and it showed a generic dual circuit master cylinder. Looking in the Corvette section of the Chassis manual shows another slightly different dual circuit master cylinder. I sent him both copies with notes to clarify the differences. There is no substitue for hands on experience. “You simply cannot book learn a Corvette.”
    Geoffrey Coenen
    • 42936
    Re: TIP: PB booster frontside rod adjustment
    Geoffrey-----
    Yes, the 68-76 booster push rod was a non adjustable pushrod of GM #3957945. It's long-since discontinued. However, it was supplied as part of booster assembly GM #338906. Unfortunately, it's also discontinued.
    Also, I agree; you "...cannot book learn a Corvette". At least, you cannot use that as a SOLE reference. It takes both experience AND "book learning".
    • Lyle C.
      • September 1, 1994
      • 3228
      I had a 73 Corvette with power brakes that did have an adjustable push rod as this is how I shortened it after questions on this board about six weeks ago with poor brakes and the rod 1/4" too long. I sure think it was original to the car but who knows.
      Lyle
      Lyle
      • Geoff C.
        • June 1, 1979
        • 1613
        Lyle,
        Wow, that is unusual. You don't have any jpegs do you?
        Did you make the adjustement under the dash area via the clevis that mounts to the pedal assembly?
        Geoffrey
        • Lyle C.
          • September 1, 1994
          • 3228
          Geoffrey
          I did not take any pictures as I thought it was no big deal at the time but I still own the car. I made the adjustment under the hood with the M/C off the rod was adjustable. I have two other boosters off a 72 and 74 I will check them out.
          Lyle
          Lyle
