TIP: PB booster frontside rod adjustment - NCRS Discussion Boards
  • Geoff C.
    • May 31, 1979
    • 1613
    Re: TIP: PB booster frontside rod adjustment
    Geoffrey-----
    Yes, the 68-76 booster push rod was a non adjustable pushrod of GM #3957945. It's long-since discontinued. However, it was supplied as part of booster assembly GM #338906. Unfortunately, it's also discontinued.
    Also, I agree; you "...cannot book learn a Corvette". At least, you cannot use that as a SOLE reference. It takes both experience AND "book learning".
    • Harmon C.
      • August 31, 1994
      • 3228
      I had a 73 Corvette with power brakes that did have an adjustable push rod as this is how I shortened it after questions on this board about six weeks ago with poor brakes and the rod 1/4" too long. I sure think it was original to the car but who knows.
      Lyle
      Lyle
      • Geoff C.
        • May 31, 1979
        • 1613
        Lyle,
        Wow, that is unusual. You don't have any jpegs do you?
        Did you make the adjustement under the dash area via the clevis that mounts to the pedal assembly?
        Geoffrey
        • Harmon C.
          • August 31, 1994
          • 3228
          Geoffrey
          I did not take any pictures as I thought it was no big deal at the time but I still own the car. I made the adjustment under the hood with the M/C off the rod was adjustable. I have two other boosters off a 72 and 74 I will check them out.
          Lyle
          Lyle
