71 REAR BUMPER MOUNTING - NCRS Discussion Boards
  • Vincent F.
    • August 31, 2006
    • 202
    For the last bolt on side of car closest to doors,is there a support bracket on underside of body for this or does bolt just go through fiberglass into bumper.I know all other bolts have support brackets under car.Service manual shows none for this
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 71 REAR BUMPER MOUNTING
    Their is none on that bolt. I think if this bolt is started first and left loose it makes the instalation eaiser.
    Lyle
    Lyle
    • Vincent F.
      • August 31, 2006
      • 202
      Lyle I went to snug up that bolt,hair line cracked my new paint.not noticable but I'm freaken out
      • Michael M.
        • April 1, 2002
        • 149
        There IS a backet - more like a support rod. In '72, there was a bushing used in the fiberglass hole to prevent the cracking. The AIM clearly shows the bracket.
        • Chuck S.
          • April 1, 1992
          • 4668
          Mike, the very first hole on the wrapped around portion actually has no bracket...there is a fiberglass reinforcing strip that doubles up the fiberglass mounting thickness there, but no bracket. I also thought there was a bracket, and had already checked Lyle's answer.
          There's a bracket attached to the frame with special grip washers, but that bracket catches the first hole on the rear portion of the bumper. The second hole to the inside has a two piece bracket that bolts together, and the hole at the bottom of the turned-down portion gets the reinforcing rod back up to the frame.
          To avoid cracking your paint and/or fiberglass, it probably makes sense to snug up the side/end bolt (without the bracket) first to allow all the other holes to "float" to that unstressed position. All the holes for bumper mounting are generous...probably for that very reason.
          • Vincent F.
            • August 31, 2006
            • 202
            Chuck I agree there is no bracket,very poor design,very little pressure causes cracking
            • Michael M.
              • April 1, 2002
              • 149
              perhaps '71's are different form '72's, but both of my '72 have bumper braces ( rods ) that attach to the rear surface of the frame.
              Paragon's page for the bracket
              • Lyle24961
                When I said left that bolt loose I should have included a warning on only to snug up this bolt. If you look lots of fiberglass is cracked at this location. I have a 71 but thougth the rear bumper was attached the same. I know 73 has the bushing and I found a washing machine drain hose with the correct OD and ID to make them out of. I know of no repop on the bushing as originals had both metal and rubber.
                Lyle
                • Bernard S.
                  • June 30, 1992
                  • 56
                  In 72's have a rod style brace was added by GM
                  • Chuck S.
                    • April 1, 1992
                    • 4668
                    According that Paragon page, the rod braces are all the same from 68 to 73. The rod braces the center bottom end of the bumpers to the frame. Vincent was asking about the bumper mounting hole on the side of the car, i.e for that portion of the bumper that turns around the corner toward the front.
                    If you've gotten anything more than a light tap on the rear bumpers, those side holes in the fender fiberglass will be broken out and needing repair.
                    • Vincent F.
                      • August 31, 2006
                      • 202
                      Bernie,so your saying 72 has support on the mounting hole closest to doors,my 71 has none there.
                        Check your copy of the AIM (Assembly Instruction Manual), UPC 14, Sheet B1... The forward portion of the rear bumper simply bolts through the rear fender, with the two rear mounting holes attaching via frame brace rods. No need to guess on this one!
                        • Vincent F.
                          • August 31, 2006
                          • 202
                          The service manual and parts manual do not show it.whats the part #
                          • Vincent F.
                            • August 31, 2006
                            • 202
                            Sorry miss read you ,you agree there is no bracket for foward hole right
                            • Michael M.
                              • April 1, 2002
                              • 149
                              So bottom line - '71's did not have the rod support, '72's did. There must have been a design change in '72 to address this. In early '72 the rod was added ( part #'s 3996869 & 3996870 ) and sometime after Jan '72 the bushing was added ( part # 6263571 ).
                              It is also interesting to note that '72 frames would have to be slightly different - as the 'cross member' end of the support rod uses a through bolt directly to a weld nut in the frame - did '71's have that weld nut ???
