63 Coup rear carpet trim - NCRS Discussion Boards
  • Carl S.
    • July 31, 2002
    • 75
    At Carlisle I stoped to Talk to Dennis Spaulding when looking at his butiful 63 saddle coup. We discued the rear vertical carpet edging and if it had trim edging on the upper edge. I told him I was about to remove my original carpet from my saddle coup. At the time I did not remember if it had the edging on the top part or not. After arving home I took some pictutes that verify that the rear has no top or side edging. My problem is I can not find the information I had to contact him. So Dennis if you read this e-mail contact me at ctschu@patmedia.net and I will send you the pictures. If any one knows how to contact him let me or him know. Dennis you may remember, I am the guy that also have the thick Harrison Label on my radiator dated 62M and not the foil as stated in the JG manual. I have seen other 63 with the thick lable as well. This is only one of maney incorect items in the manual.
    Carl T Schubauer
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 63 Coup rear carpet trim
    Carl,
    I also have an 62M radiator in my 63 with a thick Harrison plate. Not exactly sure when that style ended and changed to the foil tag. Probably Feb or March of 63? Does anyone know for sure?
    • Harry Sadlock
      Michael, I have a 63C with foil.
      Harry
      • Michael H.
        • January 29, 2008
        • 7477
        Thanks Harry. Looks like the change was in January or February 63.
        • Sydney G.
          • February 1, 1994
          • 443
          Hi Carl,
          I believe that Dennis is from NJ.
          If you contact Andy Cannizzo I'm sure that he will know Dennis' number.
          Syd
