71 dash wiring harness - NCRS Discussion Boards
  • Vincent F.
    • August 31, 2006
    • 202
    Did all harnesses have the neutrel safty switch plug for both auto trans at shift area and clutch switch area,or did you need RPO M40 for plug at shifter good question right?
    Re: 71 dash wiring harness
    There were different instrument panel harnesses for manuals and automatics; manuals accommodated the clutch safety switch on the pedal support and the transmission-mounted backup light switch wiring through the firewall, and automatics accommodated both the neutral safety switch and backup light switch in the base of the automatic shifter, among other differences.
    • Vincent F.
      • August 31, 2006
      • 202
      Thats correct,but I beleive there was one harness that would have both sets of plugs for either tranny.The backup switch plug reaches both shift area for auto,and tranny for 4sp.
        2 Dash Harness in '71--with/without AC... *NM*
        • Vincent F.
          • August 31, 2006
          • 202
          Re: 2 Dash Harness in '71--with/without AC...
          Jack,everything else on harness is same accept for a/c wiring right.
          • Dick W.
            • 10483
            AC is an add on separate harness.
            Dick Whittington
            • Vincent F.
              • August 31, 2006
              • 202
              The question is about neutral safty plugs for auto and 4sp in same harness
              • Geoff C.
                • May 31, 1979
                • 1613
                Accentuate the Positive
                • Vincent F.
                  • August 31, 2006
                  • 202
                  Re: Itz really oOSOEZ
                  Thanks Geoffrey,I knew that,
