sealing vac lines on a c3 - NCRS Discussion Boards
  • Calvin C.
    • May 31, 2002
    • 240
    I am checking and replacing vac line in my to be c3 daily driver. I have noticed on some conection there seems to be a substance maybe for sealing. Is there something to put on fittings to help avoid leaks.
    cal
  • Terry Westrick
    Re: sealing vac lines on a c3
    I would clean male posts. If replacing hoses that should do it. If using old hose I might use a sealer as in white grease to seal the old hose.
    • Calvin C.
      • May 31, 2002
      • 240
      What about pure silicon as a sealer,
        Silicone isn't a good idea - will allow the hoses to slip off the nipples. The plant used "rose water" (50-50 mix of alcohol/water) to ease assembly of rubber hoses to plastic nipples - it evaporated and left no residue.
          Tip...
          take a razor blade and cut the hose a 'tad' shorter to eliminate any that's fatigued due to years of expansion at connection points...
