'69 BB Ignition Wire Radio Shields - NCRS Discussion Boards
  • Kent K.
    • December 1, 1982
    • 1139
    My '69 BB has replacement (red) silicone wires with, what appear to be, the ignition shieldings which were part of the initial assembly. I would like to replace the wires with correct ones but retain the shielding. Do the weather boots at the distributor end of reproduction (non-shielded) plug wires from 'Lectric Limited slide off? If so, I could remove the shielding from the RED wires and place them on the new reproduction wires.
    Thanks for your assistance,
    Kent #6201
    P.S. Trying to get it running to take it to Old Town in January. You've probably seen enough of my '67.
    Kent
    NCM Founder - Member #718
