1959 Stamp Pad - NCRS Discussion Boards
1959 Stamp Pad
  • Jimmy J.
    • May 31, 1988
    • 304
    1959 Stamp Pad
    Could someone post a picture of an original 1959 stamp pad with the letter 2 in it. Thanks, Jimmy
  • Jimmy J.
    • May 31, 1988
    • 304
    I mean the Number 2 *NM*
    • Jim D.
      • 2882
      Re: 1959 Stamp Pad
      Here's a "519" block cast L159.
        Nice example!
        Note the use of two different '2' characters in the stamp. Looks 'righteous' to me...
        • Dave Suesz
          Interesting- the second 2 doesn't match. *NM*
          • Jimmy J.
            • May 31, 1988
            • 304
            Re: Nice example!
            Would these number characters (2s) be typical to a 59 Corvette? Thanks, Jimmy
              Might be...
              The gang stamp was opened and dies changed (suffix code for this run of engine, then this other run of engines) throughout the work day. Then, when the day changed physically, the date die(s) were changed. Last, when the month changed, those dies further upstream in the gang were changed.
              Now, if a given die broke, it was changed too. Also, if during the process of changing dies in the gang, the stamp agent happened to drop the gang and lose/scramble dies, the order might have changed.
              Bottom line, those who judge and are 'expert' in the art, generally keep private notebooks based on 'original' cars they've encountered and look for 'trends' in the font (What specific shape '2' or '0' or '4' is known to have been in what relative position at what time?).
              No, it's not a 'solved science' and it's VERY much an artform of determining what's 'correct' for a given engine built at a given time... But, the example shows clearly, there wasn't just one '2' in the stamping die inventory!
              • Jim D.
                • 2882
                Re: Nice example!
                This motor was found in a 64 Chev. Implala 4 door that was wrecked, parked, & junked over 30 years ago. The last time this motor ran, nobody had even heard of a re-stamping a motor. I'm 100% positive this one is for real. I don't know what it originally came in but it has been rebuilt at one time as it has been bored out.
