C2 Hood - NCRS Discussion Boards
C2 Hood
  • Clark D.
    • August 31, 2004
    • 50
    C2 Hood
    I have the hood off and the engine out of my 66 coupe for a winter project. Is there a recommended way to store the hood to prevent any warpage? Or is it even an issue to be concerned about?
    Thanks in advance
    Clark
    #42490
    Re: C2 Hood
    Just prop 'er up against a wall somewhere where it won't be hit, bumped, moved...
    • Gary B.
      • February 1, 1997
      • 6979
      C2 Hood; store under the bed.
      Clark,
      A C2 hood will fit nicely under a double size bed, with enough room around the edges so that the vacuum cleaner doesn't hit it.
      Gary
      • Kent D.
        • February 1, 1992
        • 100
        Re: C2 Hood
        If you lean it against a wall make sure you protect the corners with some foam.
        • Gerard F.
          • June 30, 2004
          • 3803
          Gary, you must have a pretty high bed *NM*
          Jerry Fuccillo
