I am a new member and I just acquired a 73 small block. There is an oil leak pooling in one of the cavities of the intake manifold. It looks like it may be riding up one of the bolts. My plan is to take the manifold bolt out, coat the threads with permatex and torque the bolt back in. Is this correct? I want to then check the torque on each of the other bolts and note there is a GM factory torque sequence to be followed. What is that sequence and the lb/ft. Can you also recommend a quality torque wrench to me.
Joe Asselmeier
Joe Asselmeier
