Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
'65 Seat belt assembly vendors -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I'm thinking of replacing the seat belts of my '65 Convertible due to a hole in the webbing of the passenger side belt and the buckles aren't that nice any more.
I found the follwing sources:
ssnake-oyl -> $290 per seat belt assembly
Paragon -> $350 - $380 per seat belt assembly
Additionaly Seatbelt Sity (Charlie Santonelli) was recommended. I would appreciate and comments about the quality of these vendors with regard to original apperance. Furthermore it would be helpful to me if anyone can provide me with an email address of Seatbelt Sity since I live in Germany and communicating by email is more convenient for me.
Charlie restored mine. Depending on a bunch of factors he charges more or less. One factor for me was the fact that he used original excellent quality black belts as compared to dyed belts which would feel stiffer. I would and have recommended him.
