I thought I might mention how I time my engines in my 55 and 67 with all the talk about timing and vacuum advance , First I don't trust the harmonica balance ( the outer ring could move)or the vacuum advance . So after the engine is warmed up and knowing it fires on all 8 OK, Carb working good. I loosen the Dist. Hold down then turn the Dist, one way or another while snapping the Carb rod full open, I do that while each time moving the Dist. Till I get NO hesitation snapping the Carb full open . Then I lock down the Dist clamp and call it DONE.
Now am I wrong ? Been timing my Corvettes that way for 40 years , could not afford a timing light when I was young and my Corvettes and cars run great with no pinging!!
