61 Rad cap - NCRS Discussion Boards
61 Rad cap
  • Ron Gaal
    61 Rad cap
    I purchased a correct (Repro)Rad cap from Paragon...The cap
    that is on now is a 13lb. the new correct cap is 7lb.
    Will this affect the cooling system right now it is perfect!!My car is an early
    61 copper rad no surge tank,.
    Thanks Ron
    Re: 61 Rad cap
    Ron -
    Won't affect normal cooling performance or operating temperature at all - the lower pressure cap will only reduce slightly the temperature at which the coolant boils and "pukes" out of the overflow.
