57 pass. side verticle ignition shielding - NCRS Discussion Boards
  • Paul Bowers
    how can I come up with a way to fasten the lower end of 57 chrome verticle pass. side shielding I ,m not going to buy or install the manifold shielding that it would normally bolt to. I just to fasten it some way, and where exactly would it bolt on the engine thanks
    paul
    Re: 57 pass. side verticle ignition shielding
    Paul -
    The tab on the bottom of the pass. side vertical shield attaches to the rear of the horizontal side shield with a wingbolt and a U-nut; maybe you could fabricate an aluminum bracket for it that attaches under the bolt that secures the lower plug wire routing bracket that takes the 4-hole grommet (section 12, sheet 10.00, item in circle "B").
    • Paul Bowers
      thanks John
      I will try to find some metel piece and try to mold it
      paul
