C2 Fuel Tank Filler Center - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
  • Alan Drake
    Re: C2 Fuel Tank Filler Center
    Loosen the tank straps all the way - push bolt up and out of cross member support. At this point tank is free to move around (low gas level please). If your tank has been in a long time it may have attached itself to frame members, but it is not bolted so it will move. Caution, watch the wring to sending unit (disconnect it).
    • Rob A.
      • December 1, 1991
      • 2126
      Dave,
      If you still have the original tank straps, you may want to use those. The straps have a tendency to reinstall the tank in the same position. Also, the original straps are a thinner and easier to bend.
      • Rob A.
        • December 1, 1991
        • 2126
        Dave,
        You can move the tank around(re-center it)fairly easy with the spare tire tub removed and the straps loosened.
        • Dave K.
          • November 1, 1999
          • 951
          Thanks to all. Made the adjustment tonite -- was fairly easy. Rob, used new straps since they have been on for four years and were well stretched.
          Dave K.
