65 L-79 350 HP idler pulley - NCRS Discussion Boards
  • tim sargent
    I have a very late 1965 327/350 HP L-79 car. It does not have an idler pulley. and it does not have a finned balancer. Is this the correct configuration for these items?
  • Donald T.
    • September 30, 2002
    • 1319
    Re: 65 L-79 350 HP idler pulley
    Tim,
    A finned balancer is correct for 65 L79. There is no consensus on the idler assembly, so the JG states there should not be a deduction either way.
    • tim sargent
      Don Ok thanks I am learning, I thought the AIM indicated that the finned
      balancer and idler pulley were for SHP only. I assumed that meant the 365 HP solid lifter car only.
      Tim
      • Verle R.
        • March 1, 1989
        • 1163
        Tim,
        I have a Feb build 65 L79 that I bought new. It came with the finned balancer but no idler pulley.
        Verle
        • James W.
          • December 1, 1990
          • 2640
          I have an original, unrestored, July '65 built L-79 equipped coupe with the finned balancer and no idler pulley.
          James West
          Omaha, NE.
          • Mike M.
            • September 30, 1999
            • 710
            I have a 65 L79 that I have owned since 1980 and it has the idler pulley it was Apr. 65 car. Mike
            • tim sargent
              Verle
              Your car must be close to mine, I have 22111. I will go with you as an original owner car, Thanks for the help
              Tim
              • James W.
                • December 1, 1990
                • 2640
                My '65 coupe is VIN #22095, K24 (July 24) body build date. The car is oringinal and has been in the family since 1974. Still has the dealer installed luggage rack on it also.
                James West
                Omaha, NE.
