OK, I need some advice from the carb experts. I searched the achieves and found some reference to this but not a complete story. My 67 327 with Holley 3810 carb has a funny throttle plate problem. Alum intake. Manual trans car. With the engine warmed up but NOT running, the throttle plates close fully and easily with the normal return spring in place. Returns to throttle stop without any hesitation with the engine off. But, with the engine idling, it doesn't always want to close all the way without a slight extra push from my hand on the linkage. If I open the throttle manually and let it close quickly, it will close all the way to the throttle stop. If I slowly open the throttle and slowly let is close (like you might do during actual drives as you approach a traffic light for example), it will hang about 300-400 rpm high sometimes. An extra push by hand will bring it down to normal idle.
It behaves almost like the throttle plates aren't properly balanced to engine vacuum like they should be, causing a force at idle in the open direction. I can see the secondary is setup to purposely load the secondary plates against the closed stop, but the primary is supposed to be neutrally balanced I think.
I can't see that my carb base throttle holes are particularly worn. Does anyone have a suggestion as to what I should check or would cause this? I can put on a stronger spring but I don't think I should have to do that. Thanks.
