I'm replacing the pilot bearing, clutch and clutch plate. How does one remove the old pilot bearing from the crankshaft? Is there a special tool? Thanks for your help. Hector
C-2 BB pilot bearing
Re: C-2 BB pilot bearing
I used a small giveaway Louisville Slugger ash baseball bat and cut it at the narrowest diameter of the taper. Then I filled up the pilot bearing cavity with bearing grease and tapped on the end of the bat with a hammer a couple times and it popped right out. PT
Attached Files- Top
