Well, I got all the little bits and peices installed from hoses, to actuators to relays and safety switches. When I try to get it all working, from wiper door opening through cycle, it just doesn't want to cooperate. I have the door off so I'm dealing with open space. Here's what's happening:
- Start the car - Door (linkage) open - wipers off.
- Turn on wipers, door closes - Wipers stay off (safety switch, o.k.) - play with the wiper switch off and on a few times and get the door (linkage) to open - wipers on, all is well
- Turn wipers off - wipers park - door (linkage) stays open
- Turn wipers back on - wiper door stays open - wipers work
- With Wipers on (and linkage open) manually press the wiper door safety switch (this is under the pass side wiper arm, and won't let the wiper door close unless the wipers are parked) the door (linkage) closes and the wipers stop mid wipe.
- Release the wiper safety switch and 3 seconds later the door (linkage) opens and the wipers resume.
I have tripple checked everything to the CC trouble shooting guide and a color schematic and it is all good. I think the control valve is the issue because somewhere during the above, I pulled the only small vacuum line off it and the door opened (I think) and I can manually pull a vacuum on it and the door closes, so I'm thinking vacuum leak on the control side. I tracked the lines through the firewall (all new just installed) and found that a small canister under the tach had an open port on it so I put a small length of hose and a plug in it but nothing (what is supposed to be there???). Should I bypass the bypass under the steering column?? If I can get the door (linkage) to open and close operating the safety switch during cycle, how come it won't close when I shut off the wiper??? Where is the electric to vacuum interface??? Anyone else home from work today too???
Thanks!!!
Jim
Thanks!!!
Jim
