What is the correct lubrication required when installing a new release bearing? I have a new bearing purchased from GM. Should the groove where the fork attaches be coated with grease, and if so, what type of grease?
Should the inside diameter of the bearing (where it rides on transmission shaft) be coated with grease, and if so what type of lubricant? It makes sense to lubricate, but I would not want grease to get on the clutch disc.
Appreciate comments on proper installation of a release bearing. Thank you.
