I've got an extra wire I'm not sure where it goes. It's not the size and color of anything in the AIM. It's red and small with a fiber wrapping. I also checked with the meter and the other end has been cut off and is behind the engine. The first pic is of the wire at the starter, the second is the cut wire behind the engine. Anyone know? I pretty sure I read that the transitor ignition uses a wire from the starter to the coil for a full 12 volts on starting. Is this it? My transitor ignition was disconnected but I'm putting it back together now. Thanks for any help!
[/IMG]
[/IMG]
