I'm installing a new balancer (GM# 6272224) on a '69 L46. Rather than buying or renting an installer, it looks like I should be able to use the threaded puller shaft with a stack of washers and a nut to press/seat the balancer on the crank. If I'm careful to keep the balancer true while pressing it on, it seems like it should work fine. Anybody tried this? Could this damage the crank or balancer? Any tips, tricks?
Thanks in advance.
Thanks in advance.
